Taz40
Jan 10, 2024Aspirant
Problem using HTTP / HTTPS Readyshare
Good morning,
I currently have a problem with my RS700 router (Firmware: 1.0.7.82_2.0.80)
I use readyshare to be able to download my files from the internet to my usb key connected to the router but I encounter a problem when I use the HTTP / HTTPS protocols (No problem in SMB)
If I start a download (2GB file) by connecting via HTTP to the router's Lan IP address, the download starts but it stops after 5 seconds then starts again from the beginning and it happens 10 times approximately before indicating that the download failed.
If I launch a download (2GB file) by connecting via HTTPS to the router's Wan IP address, the download starts but it stops after 5 seconds indicating in Chrome "Network Error"
I tried to change the USB key and also to start the download from other devices but the problem is the same.
Thank you in advance for your help.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Does this happen in other browsers as well?
- BH_CNETGEAR Expert
I believe our Readyshare does not support upload/write through HTTP/HTTPS. You can only upload files to the attached USB storage device through FTP or SMB.
- Taz40Aspirant
Yes, that's what I'm trying to do.
I forgot to specify that I only had this problem with files larger than 1.5GB
- Taz40Aspirant
The problem is not the modem, that's why I specified that I did the test in HTTP on the LAN IP address (RS700)
I wonder if we implemented the HTTP/HTTPS PUT function. We will look into it.
