Freaky
Jul 04, 2026Initiate
IOT device fails to communicate to cloud
Subject: RS280 Protection Engine Blocks Beatbot AquaSense 2 Pro Cloud Registration Router Information Model: NETGEAR Nighthawk RS280 Firmware: V1.2.7.2 Internet Configuration AT&T BGW320-505 ...
Aurion64
Jul 09, 2026Aspirant
Thanks for the update there a section in router that has IOT, can I add Telsa Powerwall there, I will raise a support to let NG know.
Do you know this IOT section?
Jul 09, 2026Guru - Experienced User
Maybe under Basic/Wireless Settings tab on the RS web page or under Advanced Tab/Advanced/Advanced Wireless.
