Freaky
Jul 04, 2026Initiate
IOT device fails to communicate to cloud
Subject: RS280 Protection Engine Blocks Beatbot AquaSense 2 Pro Cloud Registration Router Information Model: NETGEAR Nighthawk RS280 Firmware: V1.2.7.2 Internet Configuration AT&T BGW320-505 ...
Aurion64
Jul 09, 2026Aspirant
Well I set it up on IOT, but does not work, can see the Access Point, that able it.
So I try this one for Nighthawk Routers and it worked:
https://kb.netgear.com/000066695/How-to-resolve-issues-connecting-devices-to-your-NETGEAR-WiFi-7-network
I'm still having issue with my printer not working as it uses Wifi as well.
Jul 10, 2026Guru - Experienced User
So your using Guest Network for your device now?
The IoT network and setting a WPA2 only mode didn't work?
What printer model is this? Does it have ethernet port by chance? if so, try ethernet connecting printer?
- Aurion64Jul 10, 2026Aspirant
So your using Guest Network for your OLD devices now? Yes work fine. i.e Fronuis Inverter, and Telsa Powerwall 2.
The IoT network and setting a WPA2 only mode didn't work? Yes do not work.
But my problem now has nothing do with NG gear.
My Workforce 60 printer which has 10/100 port is stuck on wrong port via wireless which I cannot see, I've try with "Epson Net config port software" but cannot see this printer via wireless, would connecting it to the 10/100 port might help you think?- StephenBJul 10, 2026Guru - Experienced User
What do you mean by "wrong port via wireless"?
Have you printed the network status sheet?
Likely yes.
