djc50plus's avatar
djc50plus
Follower
Jul 23, 2025
Replace Verizon FIOS Router with Netgear
I have Verizon FIOS with a CR1000A router and TV service with Verizon. I am looking to replace the router with a Netgear router. (I currently have an older router, Nighthawk AX5400. Which is a good router, but it doesn't support the Ethernet speed.) Can someone recommend the best router to purchase? I need a greater WIFi range.
Cheers,
Dennis
  • FURRYe38's avatar
    Depends on if there is a separate ONT before the CR router or does the CR router handle the ONT side as well. Something to ask the ISP about and some Fiber ISP services may have special requirements or configurations needed to use there equipment or external routers like NG.
    Contact them first and see.
    NG doesn't produce any ONT equipment. Just routers and MESH systems that can connect to ONT equipment. Something to take a look at here to see what your home networking needs maybe or would best fit:
    https://www.netgear.com/home/wifi/mesh
    https://www.netgear.com/home/wifi/routers
  • plemans's avatar
    Is the CCR1000A acting as an ONT?
    And you have TV service?
    Why the desire to move away from that setup? Whenever I've seen users with extra services try to move to just a 3rd party device, it usually effects one of those services.
