Ricgonzalez14's avatar
Apr 13, 2026
RS140 Previously configured device does not connect to the Wi-Fi network.
Hi, I have my company laptop and it ran out of battery while connected to my company's VPN. It also uses Cisco Anny Connect. After recharging, it won't connect to the Wi-Fi network with my RS140 router. I've already restarted the modem and router, and removed the network from the laptop. The other devices are still working fine.
  • CrimpOn's avatar
    CrimpOn
    Can you do a restart on the laptop to ensure that Cisco Any Connect is not running and then search for available WiFi connections?
    • FURRYe38's avatar
      Forget the wifi profile on your laptop that had been connected to the router. They try to re-connnect.
      Contact the companies IT group for help and support with that laptop since it had been connected prior.
  • CrimpOn's avatar
    CrimpOn
    Does the RS140 WiFi network appear as "available" on the laptop?
    Is there an error message?
  • CrimpOn's avatar
    CrimpOn
    Will the laptop connect to any other WiFi network?  such as...
    • Guest WiFi on the RS140?
    • Hot Spot from a cell phone?
    Does the RS140 have any features enabled which regulate device connection, such as
    • Access Control
    • Smart Parental Controls
    • Armor
    • Ricgonzalez14's avatar
      Ricgonzalez14
      Yes, it connects to another network (mobile, work Wi-Fi, Ethernet cable to the router). I don't have guest network, Armor, Parental Control, or Access Control enabled.
  • CrimpOn's avatar
    CrimpOn
    Truly odd.  It was working correctly... and now it's not able to connect.
    This sounds like opening the Network settings clicking on the WiFi network name, and then clicking on "Forget".
    (which then allows the user to click on the WiFi network name, enter the password, and then click "Connect".
    correct?
  • plemans's avatar
    Might even check with the work IT department to see if there's any known issues with that happening.
    If you hardwire in the laptop, will it connect?
    • StephenB's avatar
      Might also be worth creating a guest network, and see if it connects to that.
