RugerSix
Feb 13, 2026Aspirant
RS180 /BE5500 5ghz radio issue "teardown" error.
Hello. I bought this RS180 Router new from Amazon (1-21-26) and out of the box even with factory ssid/ setting it started out with the default "Netgear 11" ssid and within 30 to 40 seconds of ...
CrimpOn
Feb 13, 2026Guru - Experienced User
The way I read the original post, 5G was enabled and the router was not working. Only by turning off 5G could he get it to work, and a router without 5G is useless.
coolwifi
Feb 13, 2026Virtuoso
OP mentioned that the issue was traced down when the 5 Ghz radio was enabled. I was asking about that.
