edwinyee82
Sep 07, 2025Aspirant
RS200 randomly disconnecting
       Hello,     My RS200 is currently experiencing random disconnects. It's intermittent and last maybe 30seconds - 1m.     ISP: Sonic Fiber w/ their modem  RS200 router since Feb 2025 w/ firmware V...
Sep 08, 2025Guru - Experienced User
Has a factory reset and set up from scratch with a ethernet connected PC and web browser been performed since FW updated?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channel configurations are currently set on the router?
What brand and model# devices are connected to the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Do a whois lookup on those WAN side IP addresses to see where they are coming from.
