edwinyee82
Sep 07, 2025Aspirant
RS200 randomly disconnecting
       Hello,     My RS200 is currently experiencing random disconnects. It's intermittent and last maybe 30seconds - 1m.     ISP: Sonic Fiber w/ their modem  RS200 router since Feb 2025 w/ firmware V...
edwinyee82
Sep 09, 2025Aspirant
Hello FURRYe38,
Factory reset has not been performed.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
     I don't remember what type of LAN cable i'm using now, but it's the same LAN cable as it was before when I had Xfinity (150mbps down). Now with Sonic Fiber (1Gbps down).
Brand: Adtran, Model: 622V
What brand and model# devices are connected to the router?
don't have all the model#s,
iPad, iPhone 12, Pixel 9, Samsung phone, Dell Latitude, Samsung Tv, Ring doorbell, Levoit air purifiers, dreo fan
What channels configuration? Could you give me more details on this?
I'll check this out first to see if it helps.
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
Sep 09, 2025Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
