Riley77's avatar
Riley77
RS280S: Problems with Serviio & Roku Media Player.
Both Items in subject work fine in my old router R6900, but not with the RS280S. I can get a WIFI and hardwired signal to the destination (blueray player), but cannot stream anything. The Serviio status page rarely shows the correct IP it should connect to and when it does unrecognized is shown. Roku works but not the Roku media player.
I have been trying to fix this for months with no luck. Any help would be appreciated.
  • StephenB's avatar
    FWIW, the earlier reply seems to be a cut-and-paste of an AI query. Multicast (igmp, etc) are not relevant since your media server doesn't use multicast.
    Can you clarify the above comment?  Is the "incorrect" IP on the correct subnet for the router?
    If not, then that is the problem.  Possibilties are that
    • you set up a static ip address on the media server that is not compatible with RS280s subnet
    • you are double-routing (perhaps due to use of an ISP gateway), and the Serviio server is connected to the gateway and not the router.
    If it is, then one possibility is that the server is set up to randomize the mac address.  Another is that the server is connected to the network twice (perhaps two NICs, or a wireless and ethernet connection).  A third is that you reserved an IP for the server in the R6900, but forgot to carry that over to the RS280S.
    If the server is running on a Windows PC, then first check that Windows has the connection classified as "private".  Windows 11 defaults to using randomized mac addresses on "public" networks.   And the Windows Firewall will sometimes block discovery if the network is set to "public" - and that will prevent the players from "finding" the server.
    Serviio is a DLNA server, so it does use UPNP.  But that should work on your local network even if the router has that disabled.  The UPNP setting in the router normally only allows a client to open a port in the router - not something needed for a local media server.   DLNA works with my Orbi router with UPNP turned off in the router.  Still it does no harm to try toggling the setting in the router.
    Have you set up the Roku media player as a DLNA player as well?
    • schumaku's avatar
      schumaku
      DLNA does make use of SSDP, the Service Discover Protocol - which is based indeed on Multicast, too.
      The UPnP settings CONTROL does (in general) allow both the discovery (again SSDP based), and the router IPv4 based NAT port forwarding.
      Technically, DLNA system is made up from three components:
      • Digital Media Player (DNR)
      • Digital Media Server (DMS)
      • Digital Media Controller (DMC)
      Discovery and usage depends fully on SSDP. Port forwarding on the router is typically not required.
      On a private home, or even on a small business network, having network devices discoverable can be very useful.
      Most hone and SMB routers don't offer dedicated controls for UPnP Discovery and UPnP Port Forwarding.
      • StephenB's avatar
        schumaku wrote:
        The UPnP settings does (in general) allow both the discovery (again SSDP based), and the router IPv4 based NAT port forwarding.
        The discovery works fine with my Orbi setup even with UPnP turned off.  So AFAICT the setting doesn't affect SSDP (or DLNA generally).
        FWIW, another user recently posted that mDNS also worked for him with uPNP turned off (but a different multicast address used by plexamp didn't work reliably on his wireless network)
  • Thanks for all the replies!
    Now I sort of have it working. I assigned a static IP in the router for the bluray player. After rebooting the PC, it works fine for about 30 minutes, then drops the broadcast.
    The Roku media player and the default Windows media server only work when the  Serviio works. I ran the old R6900 with no special settings and everything was fine.
    Any more suggestions or any above I missed and should try?
    • StephenB's avatar
      Did you set up the Windows Media Player as a server?
      If you did, have you also checked that the PC has classified the network as private?
      • schumaku's avatar
        schumaku
        The legancy Media Player Its not a server - it can "just" play local stored media.
        Windows 11 is offering a Media streaming feature, acting as a DLNA server -if- enabled.
        Control Panel -> Network and Internet -> Network and Sharing Centre -> Media streaming options where you can choose Media Streaming Options for Computers and Devices
        Media streaming is not turned on
        Media streaming allows you to send your music, pictures and videos to other computers and devices on your network. It also allows you to receive media from other computers and devices.
        If you turn on media streaming, your current network profile and firewall settings will be modified. You should turn on media streaming only on networks that you trust, such as home or work networks.
        [>> Turn on media streaming]
        Alas, for once this appears to have no impact - the media streaming option applies to the current network profile in my reading and understanding.
        The legacy Windows Media player can list and play local files as well as multiple DLNA Servers available on the network.
        Of course, both of these two DLNA services can be configured pointing to different, dedicated media folders - which don't have to be the same.
        By default, the Media streaming service does work (unless configured differently) in the Windows default media folders for Pictures, Music, Videos. If there are no media stored under these folders there isn't a lot of media visible there. This cloud explain why you have to run the Serviio server to see DLNA media.
