giubeca's avatar
giubeca
RS300, firmware 1.0.6.16; Ethernet Settings
I'd like to configure the port aggregation to connect a switch to the port 1 and 2. Following the user manual on page 99, on the page ADVANCED>AdvancedSetup>EthernetSettings the port aggregation is disabled and it's asking me to disable VLAN to enable it.
But I need the VLAN configuration to connect my ISP; how have I to do?
  • CrimpOn's avatar
    CrimpOn
    Sorry I was not clear.  Suggest replacing the existing gigabit switch (which supports port aggregation) with a new 2.5G switch (which does not need port aggregation because it can connect directly to a 2.5G port on the router.)  The existing gigabit switch might be used for some other purpose.
  • CrimpOn's avatar
    CrimpOn
    The VLAN setting required by the ISP is which type:
    • By bridge group?
    • By VLAN tag group?
    This may be a situation where the only practical solution is to replace the existing gigabit switch that supports port aggregation with a 2.5GB switch.  When connected directly to one of the 2.5GB LAN ports, such a switch will provide more aggregate bandwidth than the port aggregation.
    • StephenB's avatar
      Or just a multigig switch, since there might not be any need for downstream port aggregation.
  • StephenB's avatar
    Do you need this for internet access?  Or are you using it for an IPTV service?  If so, is the IPTV device connected to the switch?
    Is the switch a gigabit switch?  Or does it support multigig?
    ella067thompson wrote:
    aggregate Ports 2 and 3 to your switch instead.
    Can't be done with the RS300, it only supports local LAN aggregation on ports 1 and 2.
  • Hello,  You can’t use port aggregation on ports that have VLAN enabled. Keep Port 1 for your ISP VLAN, and aggregate Ports 2 and 3 to your switch instead.
