pkaytes's avatar
pkaytes
Guide
Feb 08, 2025
RS500 How often should DDNS send updates?
I'm taking advantage of the Netgear DDNS service. I would think that the router would periodically send an update to no-ip (the underlying DDNS provider) but I only see one update (the no-ip website shows the last update received and it coincides with the reboot of the router). In fact after a couple of days, when checking the status of DDNS on the router, I get the following error:
and I'm sure no-ip isnt down.
The firmware is 1.0.1.60
Your thoughts?
  • FURRYe38's avatar
    BH_C
    • pkaytes's avatar
      pkaytes
      Guide
      Not helpful.
      Netgear CM3000, which has nothing to do with the question.
    • pkaytes's avatar
      pkaytes
      Guide
      I've installed fw 1.0.6.16 on the RS500 and it still does not update the DDNS provider (no-ip in my case) every 24 hours.
      • StephenB's avatar
        Has the WAN IP address of the RS500 changed?
