GreggF
Apr 17, 2026Aspirant
RS600 -v- RS700
I recently upgraded my internet service to 3Gbps and want to upgrade my router.
For a small house is the RS600 future proofed enough or should I bite the bullet and buy the RS700?
Thanks
Whats the size of the home? RS600 is a good router.
How many devices do you have?
- GreggFAspirant
<2500 sft
Total max of 5 devices.
Either would work.
I would look at the spec sheets between each model and see what the main differences are and see if higher speeds is what you need with the RS700 or the 600 should be suffient.
