ipg8x
Jan 14, 2026Guide
RS700 - 5GHz Wifi - Channel Auto 40
Hello,
I have noticed my wifi 6 (802.11) devices are getting a slower connection around 180mbps, it used to be around 350-450 mbps when performing a speed test.
Upon looking into router configuration, I can confirm the wifi 5GHz is set to Channel: Auto and Mode: up to 5.8 Gbps. However if I click on Advanced Home and scroll down to see the wireless configuration, I do see channel Auto (40) and mode up to 0.7 Gbps.
If I change the channel manually to higher upwards of 128, I do get better speeds on wifi 6 devices.
Any reason why 5GHz auto channel is default to channel 40? How do I correct this manually without choosing a specific channel?
Router Model: Nighthawk RS700
| Firmware Version | V1.0.10.8_2.0.109 |
Thanks
CT
Possible AUTO setting for 5Ghz and the FW system maybe seeing interferences on other channels and picking a lessor noisy channel. Something that the FW systems handles.
I use channel 40 all the time here. However mostly use 48 on my RS700 as I have other noisy channels near by.
You don't have to use AUTO setting. Pick something that works best for your environment. Manual works well. Can try the other channels. Pick something that works best for you.
- ipg8xGuide
I have on channel 161 for 5GHz and has been good for few weeks.
- coolwifiLuminary
Are you using channel 161 with up to 5.8 Gbps speed? You might have to check whether all of your 5 Ghz devices support the UNII-4 Ghz channels 169-177, if they don't they will connect to the router at a lower speed. The solution for this is to change the speed to 2.8 Gbps which will lower the bandwidth to 80 MHz.
- ipg8xGuide
thanks for the info. I will double check. Most of my wifi devices are under couple yrs old and when I tested them all post change I was getting around 350-550 mbps. Will check if they support UNII-4 GHz. I picked 161 channel to avoid interference with my neighbours.
- morrijasTutor
I have had the same issue with my RS700S after the firmware upgrade my 5ghz band went from connecting at 1.4 gig wireless to my media bridge but after the update the speed dropped to 400 meg, I went in to wireless and changed the channel from AUTO to 149 and my speed picked back up to 1.2 gig so the new firmware jacked up the 5ghz being on auto
- coolwifiLuminary
The auto 5 Ghz channel setting might choose a channel which is not used and it might be a DFS channel with a lower transmit power and hence the speed drop.
- coolwifiLuminary
Don't rely on the auto channel selection in the 5 Ghz band, choose the least used channel 36-48 or 149-161 depending your neighboring 5 ghz wifi channels. Channel 44 provides the best performance in my RS500 router. Higher DFS channels might be clean but you might get kicked out of those channels if any radar interference is detected,
