Intoxicating
Jun 16, 2026Star
RS700 DNS issues
Hi,
I’ve noticed what appears to be DNS leakage in the latest two versions (1.0.11.8 & 1.0.11.6)
I use custom DNS for adblocking and with both versions I’ve seen what would normally be blocked being unblocked. Suspect that after a while the RS700 is using the ISP WAN supplied DNS as well as the custom DNS as the blocking / unblock is random.
When I first noticed it a few weeks back I downgraded back to 1.0.10.8 and had zero issues, everything that would normally be blocked stayed blocked.
Upgraded to 1.0.11.8 when it was released and once again started seeing the issues.
Happens on IPv4 & IPv6 - have tried with IPv6 disabled, same results.
Have today downgraded back to 1.0.10.8.
Thanks,
Tim
Any news on the issue?
Thanks,
Tim
Not yet. Can only presume next FW update.
- coolwifiVirtuoso
My ISP DNS servers are fast as cloudflare or quad9 or Google DNS in my location.
- coolwifiVirtuoso
It's evident that Netgear is adding the primary cloudflare ipv4 DNS server 1.1.1.1 to the user configured or ISP DNS servers with the latest firmware updates for the RS500/600/700 routers as seen from the various user posts here.
I've asked NG to see what is expected behavior for the Automatic DNS setting on RS Routers. Seems that auto is default and is using Cloudfare that NG has set for this option currently.
I'm using custom DNS on my RS600 and RS700 currently.- FURRYe38Guru - Experienced User
Just updating this. NG seems to have a backup DNS which is a 3rd DNS service used in case if the primary DNS fail to respond. However, the handling of the detection of the DNS services and the order they are prioritized isn't to what NG is expecting.
NG is aware of this and is working on it.
Please be patient.
I just tested with old version via browser leaks and only NextDNS showed up, upgraded to 1.0.11.8 and NextDNS showed up along with Cloudflare.
Thanks,
Tim
Yeah, that's pretty clear.
Which seems like it must be intentional behavior. It'd be good to know the rationale.
Did you confirm this? One way is to use the DNS test at BrowserLeaks.com.
coolwifi is seeing that CloudFlare is being added as a DNS server with the RS500, FURRYe38 is seeing that the "automatic" setting is using Google+CloudFlare, and ignoring the ISP DNS server.
So something odd here, that might also apply to the RS700.
I’ve got the old working version on at the moment but my ISP (Zzoomm) use Cloudflare and Google as DNS, I use NextDNS.
One.one.one.one appears in my logs with versions 1.0.11.8 & 1.0.11.6 installed but doesn’t with the older.
I was also seeing that on an Adblock test that on the old version I get 98% blocked but on the newer versions it was impossible to get everything blocked that would normally be blocked.
I’m pretty confident the 1.0.11.6 version has introduced the bug.
