Jack-L-Lantern
Jul 10, 2025Follower
RS700 firmware update 1.0.9.6 breaks Windows Server DCHP
For context, I use Windows Server 2019 DHCP for my DHCP Server, so I disable the DHCP feature on the router. After the 1.0.9.6 update I found that the Windows DHCP Server was broken and gave the erro...
Jul 10, 2025Guru - Experienced User
You might contact NG support as well. There are currently other users seen problems with the newer version of FW so you might revert back to prior working version of FW.
RS700 firmware update 1.0.9.6 | NETGEAR Communities
NG is looking into this already.
