DLAUS
Jul 08, 2025Aspirant
RS700 firmware update 1.0.9.6
Hi
After upgrading to 1.0.9.6, something has prevented some of my 2.5ghz devices from being able to connect to wpa2/3 setting when smart connect is enabled.
the only way to resolve was to disable smart connect and change security to wpa2 only, or downgrade firmware which I have now done, and everything is working perfectly again.
Has anyone else had this issue?
Thanks
What channels are you using on the router? Try 1 and 40.
Did you factory reset and setup from scratch after v.6 FW was loaded to see if this helps any?
Similar problem here. I have a Honeywell thermostat that will not reconnect to the router since the firmware update. I've tried repeatedly to enter the password for the primary network and the guest network and it will not allow the thermostat back in. Hitting the WPS button while submitting the password did not help either. I also had to reconnect a ring camera after the firmware update. This has been a very frustrating update.
- rawintellectApprentice
Have you tried my suggestion? It really did fix it right up for me. Both my Direct TV receiver and my Honeywell thermostat had the problem.
I am interested in trying this suggestion. I'm not very astute on IT matters...if I'm not hardwired to the router, after I uncheck "enable wireless radio" and hit apply, will I still be able to wirelessly connect to the router to recheck and hit apply? In other words, will my computer still be able to log into the router admin panel wirelessly to reject the box? I use a wheelchair it's just not physically possible for me right now to hardwire my device into the router, if necessary.
- jsheehanGuide
Tried the turning off wireless radios and also doing a factory reset . . . neither worked for ALL me devises (most did work though). The one major one that would not work was MYQ garage door hub. Ended up going back to the previous firmware 1.0.7.96 and now everything is working again. Guess I will just wait for the next update and try that one.
- BH_CNETGEAR Expert
Thank you all for reporting the issue and the workaround, and we are sorry for the troubles. We will look into it right away.
Once you disable all the radios, all yur WiFi devices will get disconnected, and you need a device wired to the router to enable all the radios again.
Thank you for the info. Just to give you an update, I installed the previous version of the firmware (1.0.7.96) on my RS 700 and everything is connecting now. I'm not an IT professional but the problems do appear to be related to the most recent firmware update (1.0.9.6).
I just noticed something I'm unclear on: after I downgraded the firmware, I checked the current version and the router displays the current version as 1.0.7.82 both on a web browser and on the nighthawk app.
However, I downloaded and installed the firmware from the zipfile for 1.0.7.96. I went back and rechecked my downloads folder and the file is named RS700-V1.0.7.96_2.0.96.chk. Any idea why it shows up as a much older version of the firmware, 1.0.7.82?
- DLAUSAspirant
I can also confirm downgrading has completely fixed the issue, I'm also not an expert by any means but it does seem to be linked to the new firmware.
- Raddip1Guide
I too am having problems after the firmware update. All devices with preconfigured static IP addresses randomly change to a different IP address. All device labeling and MAC addresses assigned to the static IP addresses randomly change as well without any user intervention.
I have rebooted, factory reset and uploading backups to no avail.
BH_C, please disregard my last post about the incorrect firmware version showing up on the router. That was user error on my part and I am now running v1.0.7.96.
- RichardTTTNETGEAR Expert
Hi,
Just wanted to let you know I’ve sent you a PM with a trial firmware—feel free to let me know if you’ve had a chance to try it out.We’re continuing to look into the WiFi connectivity issue and really appreciate everyone’s input. If anyone else is seeing similar behavior and would be open to testing a debug firmware, feel free to PM me directly.
Thanks again for all the support!
Hi Richard,
I responded to your DM a while ago.
Hi everyone, if some of your WiFi devices cannot connect to RS700 after the firmware is upgraded to v1.0.9.6, please let us know which WiFi devices they are (brand, model, and firmware / driver version if you know). We will see if we can find the same devices to test.
Also it is much appreciated if you are OK to run some trial firmare to see if that fixes the WiFi connection issues for you. Thank uou.
- Raddip1Guide
For me, it is not that there is a problem with devices connecting. They all connect fine. The problem is that the static IP addresses that were set with those devices along with the assigned MAC address and naming conventions randomly change without any user intervention. Ie, rebooting, etc. This happens when I am not even home or overnight when I am sleeping.
This becomes a problem for me as I have a pretty sophisticated smart home environment with several platforms, Ie, Apple HomeKit, Home Assistant, Homebridge, Smarthings, Hubitat, and Amazon Alexa. All of my hubs talk to each other locally via assigned IP addresses. When the IP addresses randomly change, the hubs no longer talk to each other and it brings down my smart home. The only way to temporarily remedy this is to reboot the router.
Additionally, even after uploading backups that were made before and after the firmware upgrade, they never load correctly where my static IP address assignments are back to the way they were. All other router functions are fine, speed, etc....
Yes, I am very willing to run some trial firmware.
- Raddip1Guide
By the way... I have logged this with Netgear support as I have contacted them. I have a case number
- jsheehanGuide
For me, the devices that I know had issues were:
Honeywell Thermostat RTH6500WF
Chamberlain MyQ Garage door Hub
B Hyve Wifi Sprinkler Timer 57946-50rb
And now that I think about it, all had static IP addresses assigned to them. There may have been more items that had issues, but I switched back to the previous firmware before testing everything.
- stanfrenchLuminary
I have the same issue with my Honeywell 9000 Series (RTH9580 Wi-Fi) thermostat and La Crosse C83100 weather station. Both are older 2GHz band only devices that worked perfectly before the v1.0.9.6 update. I was able to get them running by linking them to my extender instead of directly to the RS700 router, but that seems to have caused those extenders to lose internet connection. When I change the 2GH band channel assignment (1,7 or 11) on the RS700, the internet connection is reestablished at the extender but usually disconnects after a few hours.
Please revert to prior working version of FW and wait for next FW update.
Since updating to 1.0.9.6, all devices have been ok on all bands apart from one device that has not been playing nicely with the new firmware, and that's my Eufy Home Base 3. Never had a problem with the previous firmware in almost a year of use, but on 1.0.9.6 with 2.4ghz it never connects with certain channels, which is a bit odd and I noticed this issue immediately the moment I manually upgraded the firmware. I know channel 2 works great with my Eufy Home Base 3, but if the router auto changes, or I do it manually to say channel 10, it completely kicks this one device off my network and I can't get it working no matter what I do. Changing this channel manually or if the router decides to move back to a working channel like 2, it connects immediately.
On the previous 1.0.7.96 firmware, I have never seen this behaviour. Out of the 35 devices I have connected, this is the only one that does it annoyingly. If this happens again, I may just have to downgrade or force the 2.4ghz band to stick to one channel until a new update is out.
As I can't edit my post, I forgot to add I don't use smart connect, so all bands are completely separate and apart from 6hgz, the other two use WPA2/WPA3 Personal with modes set to the highest bandwidth.
Quick update, I've now downgraded the firmware back to 1.0.7.96 over the top of the latest one, and the one device that was playing up the eyfy home base 3 is now working no mater what channel 2.4ghz is on. Until whatever pretty serious bug has been added to the latest firmware, I’m going to have to stay on 1.0.7.96 for the moment.
- Raddip1Guide
Is there any ETA on a fix?
I had this same issue with a newer Orbi system
If you have connection issues with WPA2 or WPA3 after the firmware is upgraded to v1.0.9.6, please let us know if you would like to try trial firmware. We've identified some possible causes and we would like to confirm if that address all the cases reported here.
Please PM RichardTTT if you would like to give it a try. Thank you.
- markhasAspirant
I did have some issues with the v1.0.9.6 firmware and Wifi performance.
I have a separate 2g band configured on a different SSID for certain IOT devices that work only with 2g and get confused when Smart Connect is enabled, so I not use Smart Connect.
A couple of these devices failed to connect to the 2g band after v1.0.9.6 firmware upgrade. Some of those devices are a Trane ConfortLink II XL1050 and a Bond Bridge Part# B07CR99LXG.
I also may have been having problems with other devices some of which are connected to the Guest network, which is isolated from the rest of the wifi networks. Those devices are Roomba robotic vacuums, Ring Cameras and Chime devices. My network has over 120 devices connected of which about 20 are Wifi.
I did not run into fixed IP address changing from static or not following reserved settings on the router, but the RS700 router DHCP range is configured so that all static IP devices are outside the DHCP range which starts at 100. If the static devices are outside the DHCP range the router should not change or assign other devices to those IP addresses.
I did also see issue with the RS700 playing nice with Netgear access points like the WAX 630E when the Wifi SSID's are the same but configured on different channels far away from the router. That seemed to work fine with prior firmware versions as well.
Hi,
I just PM with a trial firmware for the issue you reported. Let me know how it goes once you’ve had a chance to try it out!
Thanks,
Richard.
- KBiiAspirant
Willing to give it a go if you still want testers.
Thanks for your detailed feedback! I’ve sent you a private message—please take a look when you get a chance. Appreciate your help!Best,
Richard
