MrChrisH
Oct 23, 2025Aspirant
RS700 VPN Service certs incomplete?
I've been setting up NoIP and the VPN Service on my RS700. I'm on firmware version V1.0.9.6_2.0.100. After much tinkering and following much of the helpful advice here, I have a connection that ...
Oct 24, 2025Guru - Experienced User
Just checking to see if you have updated FW to check this?
Nighthawk Firmware Releases | NETGEAR Communities
MrChrisH
Oct 24, 2025Aspirant
Thanks for checking, yes, I'm on firmware version V1.0.9.6_2.0.106. I updated fw again this AM, as I noticed a very recent new version, and reconfigured openvpn and downloaded config files from the router.
I still get the "Certificate does not have key usage extension" error and the connection fails when I include remote-cert-tls server in my config.
- FURRYe38Oct 24, 2025Guru - Experienced User
FW version should be v.16 though. Can you confirm this?
- MrChrisHOct 24, 2025Aspirant
Sorry, yes, I've just double checked on the router, it's V1.0.9.16_2.0.106, so yes, v.16
Ok, passed this on to NG for review.
For reference what brand and model # ISP modem/ONT is connected to the RS router?
Any other troubleshooting been performed to check this?
What device brand and model# are you using?
