Intoxicating
Jul 03, 2025Star
RS700 WAN lease issue
Hello,
I've got an issue where by the WAN lease doesn't get renewed before expiry which then causes the Internet to be disconnected until restarting the RS700 (app & web login becomes unresponsive)
Issue has only appeared since update to V1.0.9.6_2.0.100
ONT has been switched off at main too but issue still happens
Thanks,
Tim
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.The ONT is an ADTRAN 622V, cable is CAT6A STP.
Thanks,
Tim
- BH_CNETGEAR Expert
Thanks Intoxicating for reaching out, and thanks FURRYe38 as always for tagging me here.
The FW v1.0.9.6 addresses some DHCP issues reported from the field (duplicate assignments, unable to get IPv6 address from some ISPs...), not sure if it causes some side effects.
Can you help collect some debug logs? I will PM you the instructions. Thank you.
