superuser2510's avatar
Apr 21, 2026
RS700s reducing speed to 90mbps.
So I have the BGW320 in IP passthrough mode and connected the blue 5GB port from the BGW320 to the WAN port on my RS700s. Intially I had connected the two with a 6ft cat5e cable and was getting a download speed of 1.1GB. After moving the router to the middle of the house and connecting them with a 32 ft cat6 cable. The speed drorpped to 90mbps. Initially I thought it was my cable but I purchased a cable that was already made and it was still same. When I plut a cat5 cable into the BGW320 I will get a download speed of 900mbps but when I plug a cable into the RS700s its just 90mbps. So not sure why the RS700s downgrading my speed. Any idea what can be causing it?
  • FURRYe38's avatar
    If the CAT5e is working and the CAT6 cables aren't, would be these CAT6 cables. Are they STP or UTP cables? I recommend CAT6A STP cabling, S is or sheilded. U is un-shielded. I get 900Mpbs with my RS700 behind my CM3000 using CAT6A STP cabling.
    What FW version is on your RS router?
    Is IPv6 and Protection Engine enabled?
    I you posted more here as well:
    https://www.reddit.com/r/NETGEAR/comments/1srqost/nighthawk_rs700s_with_attt_bgw320500
    • superuser2510's avatar
      superuser2510
      Using a UTP cable but I'll give a STP a try.
      FW version is v1.0.10.8
      Not sure about IPv6 Protection Engine if its on or not.
  • CrimpOn's avatar
    CrimpOn
    This is the speed reported by the RS700 web interface or the Nighthawk app, correct?
    Does the RS700 web interface have a feature that displays the status of port connections, similar to this?
    What does it show for the status of the WAN port?
      • FURRYe38's avatar
        So 100M shows for CAT6 and CAT5e shows 1000M? If so, then your issue would be the particular CAT6 cabling your using?
