parsoni's avatar
parsoni
Spectrum Modem, Netgear RS700 Issues
I've recently started seeing that the Spectrum App (on Phone and Apple Box) and also streaming via watch.spectrum.com when operated in my home are NOT seen as connected to Spectrum Internet.
I've spent hours on tech calls with Spectrum and am in the ultimate position of "it must be your router".
My RS700 has the latest firmware, downloaded from Netgear last week.
Inbound bandwidth is >1000Mb/s, Outbound typically around 43Mb/s.
It's driving me crazy.  Any ideas on settings gratefully received.
Thanks in advance.
  • FURRYe38's avatar
    Do other apps work when connected?
    What brand and model mobile device is the app installed on?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
  • So - Spectrum needed to reprovision my modem - more than a restart - remove from net and re-assign , then it all worked.
    • CrimpOn's avatar
      CrimpOn
      parsoni wrote:
      then it all worked.
      Perhaps you could mark the problem "Solved"?
  • I suspect it's since they updated to utilize IPV6 - but no real proof.  :-)
    • FURRYe38's avatar
      What happens if you disable IPv6 on the RS router if it's enabled?
      Also try watch.spectrum.net?
      I get this when using .net:
  • CrimpOn's avatar
    CrimpOn
    Does the RS700 show these devices as "connected"?
