Jimmdean
Oct 18, 2024Aspirant
Unable to use LAN aggregation on RS280 with VLAN tagging enabled
I have to use VLAN tagging for my internet, but LAN aggregation is disabled along with WAN aggregation when you have VLAN enabled. Is this a technical limitation? I'm no expert on VLANs, but I would think you should be able to aggregate LAN ports 1 and 2 regardless of how the WAN port is configured. Thank you.
Sorry, we've looked into this and it is a limitation on RS300 and RS280 that the VLAN function and the link aggregation function cannot be both enabled at the same time.
Ya something that may not be supported in that kind of configuration. Let see if NG can help with some feedback on this one.
- BH_CNETGEAR Expert
Looks it's a known issue and we still work on it.
- JimmdeanAspirant
I've considered disabling the VLAN temporarily to configure the lan aggregation, then re-enabling the VLAN to see if they can co-exist when done in that order. Maybe you can warn me against that if you know it will not be successful.
