LuckeeC14
Sep 13, 2026Aspirant
WiFi calling not working
Got my parents a new Nighthawk RS180 and now the WiFi calling for their Apple phones (AT&T) is not working. They need it as there is 0 cell service at their house.
I turned off Armor and disabled SIP ALG. What is going on???
Brand and model# ISP modem/ONT that the RS router is connected too?
- LuckeeC14Aspirant
It is a Calix GP1100G ONT
What iOS version is on the phones?
Has any other phones been tested at the parents place? i.e. Android or your phone by chance?
ONT is an ONT only so no router there.
Any Armor, SPC or IPv6 enabled on the router?
Might try putting the IP address of the iPhone it gets from the router into it's DMZ to see if WiFi calling works, as a quick test.
Do the phones work at other locations with WiFi calling? Say your place or a friend or neighbor?
Something you should check into, Ask ATT for a micro cell device if that could be of help for your parents. Something I have at my place since we get little cell service signal. Just a cell service AP that connects to your router and you put a signal sensor near a window. This gets a satellite signal for authentication is all. Phones connected to the microcell AP. All calls made thru the microcell goes thru the router and internet services.
Are their phones connected to the new wifi? (Try disabling mobile data, and see if they can reach a web site with that turned off).
- LuckeeC14Aspirant
Forgot to mention in original post that I’m a network admin. Assume that I’ve done all trivial steps. Yes, their phones connect to wi-fi and it is working fine.
