WebHostWala
May 27, 2016Follower
6.5.0 Firmware upgrade causes network access issues
Im also facing the same issue, on network it becomes inaccessable over IP.
I have no options but the F-restart. Is there any option where this issue is addressed or how do i down grade to the o...
mdgm-ntgr
May 27, 2016NETGEAR Employee Retired
Split your post into a new thread.
Have you saved credentials for logging into the NAS?
Does your PC use the same username as your NETGEAR usernarme?
Does your local user have the same email attached to it as your NETGEAR account?
Downgrading is not recommended.
xraystyle
Jul 02, 2016Tutor
Bumping this thread, I believe I have the same issue here.
I recently upgraded my Pro 6 from I believe 6.2.4, which was rock-solid, months of uptime with no issues.
After upgrading to 6.5.0 I've had what seem like two hard freezes in the last two weeks. The NAS seems to drop off the network. It won't respond to ping, I can't ssh to it, none of the shares are accessible, I can't reach the web interface, nothing.
The power button on the front panel is unresponsive, pressing it doesn't bring up the LCD screen. It seems to be locked up. I had to hold the power button to shut it down, then reboot it. Both times this brought it back up and it starts working again.
I began digging into the logs to see if there was anything I could find that looked immediately wrong, and I couldn't see anything right out of the gate, but I started going back through the syslog to see if I could determine at least what time the system actually froze.
I found this entry in kernel.log, checksum failure for the NIC that's connected to the network:
Jul 02 06:20:49 blackbox kernel: [295890.975286] eth0: hw csum failure Jul 02 06:20:49 blackbox kernel: [295890.975299] CPU: 0 PID: 0 Comm: swapper/0 Tainted: P O 4.1.21.x86_64.1 #1 Jul 02 06:20:49 blackbox kernel: [295890.975303] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080014 10/03/2008 Jul 02 06:20:49 blackbox kernel: [295890.975305] 0000000000000000 ffff88014fc03b08 ffffffff889b0fe5 ffff8800ab8f4000 Jul 02 06:20:49 blackbox kernel: [295890.975310] ffff88009dbc6501 ffff88014fc03b28 ffffffff888af96d ffffffff8889c4b0 Jul 02 06:20:49 blackbox kernel: [295890.975314] ffff88013741c200 ffff88014fc03b68 ffffffff888a3e47 ffff88014fc03b48 Jul 02 06:20:49 blackbox kernel: [295890.975318] Call Trace: Jul 02 06:20:49 blackbox kernel: [295890.975320] <IRQ> [<ffffffff889b0fe5>] dump_stack+0x4d/0x63 Jul 02 06:20:49 blackbox kernel: [295890.975334] [<ffffffff888af96d>] netdev_rx_csum_fault+0x3d/0x40 Jul 02 06:20:49 blackbox kernel: [295890.975338] [<ffffffff8889c4b0>] ? csum_block_add_ext+0x30/0x30 Jul 02 06:20:49 blackbox kernel: [295890.975342] [<ffffffff888a3e47>] __skb_checksum_complete+0xc7/0xd0 Jul 02 06:20:49 blackbox kernel: [295890.975347] [<ffffffff88913f78>] icmp_rcv+0x1f8/0x3b0 Jul 02 06:20:49 blackbox kernel: [295890.975351] [<ffffffff888df7c4>] ip_local_deliver_finish+0xa4/0x220 Jul 02 06:20:49 blackbox kernel: [295890.975354] [<ffffffff888dfab6>] ip_local_deliver+0x36/0xb0 Jul 02 06:20:49 blackbox kernel: [295890.975357] [<ffffffff888df720>] ? ip_rcv_finish+0x310/0x310 Jul 02 06:20:49 blackbox kernel: [295890.975360] [<ffffffff888df521>] ip_rcv_finish+0x111/0x310 Jul 02 06:20:49 blackbox kernel: [295890.975363] [<ffffffff888dfd7e>] ip_rcv+0x24e/0x3c0 Jul 02 06:20:49 blackbox kernel: [295890.975367] [<ffffffff888aa85c>] __netif_receive_skb_core+0x53c/0x750 Jul 02 06:20:49 blackbox kernel: [295890.975370] [<ffffffff888adb8c>] __netif_receive_skb+0x1c/0x70 Jul 02 06:20:49 blackbox kernel: [295890.975373] [<ffffffff888add2e>] netif_receive_skb_internal+0x1e/0x90 Jul 02 06:20:49 blackbox kernel: [295890.975377] [<ffffffff888addac>] netif_receive_skb_sk+0xc/0x10 Jul 02 06:20:49 blackbox kernel: [295890.975382] [<ffffffff88747e43>] SkY2Poll+0xeb3/0x14b0 Jul 02 06:20:49 blackbox kernel: [295890.975386] [<ffffffff88087b4d>] ? get_nohz_timer_target+0x3d/0x100 Jul 02 06:20:49 blackbox kernel: [295890.975389] [<ffffffff88088001>] ? task_curr+0x1/0x30 Jul 02 06:20:49 blackbox kernel: [295890.975393] [<ffffffff888ae0ec>] net_rx_action+0x12c/0x2c0 Jul 02 06:20:49 blackbox kernel: [295890.975397] [<ffffffff8806b66a>] __do_softirq+0xda/0x1f0 Jul 02 06:20:49 blackbox kernel: [295890.975401] [<ffffffff8806b966>] irq_exit+0x76/0xa0 Jul 02 06:20:49 blackbox kernel: [295890.975404] [<ffffffff880052d0>] do_IRQ+0x60/0x100 Jul 02 06:20:49 blackbox kernel: [295890.975408] [<ffffffff889b972b>] common_interrupt+0x6b/0x6b Jul 02 06:20:49 blackbox kernel: [295890.975410] <EOI> [<ffffffff8800cbfb>] ? mwait_idle+0x5b/0x90 Jul 02 06:20:49 blackbox kernel: [295890.975417] [<ffffffff8800d4aa>] arch_cpu_idle+0xa/0x10 Jul 02 06:20:49 blackbox kernel: [295890.975420] [<ffffffff8809c6da>] cpu_startup_entry+0x18a/0x2a0 Jul 02 06:20:49 blackbox kernel: [295890.975424] [<ffffffff889ab032>] rest_init+0x72/0x80 Jul 02 06:20:49 blackbox kernel: [295890.975428] [<ffffffff88e38003>] start_kernel+0x4b1/0x4be Jul 02 06:20:49 blackbox kernel: [295890.975431] [<ffffffff88e3793f>] ? set_init_arg+0x58/0x58 Jul 02 06:20:49 blackbox kernel: [295890.975435] [<ffffffff88e37568>] x86_64_start_reservations+0x2a/0x2c Jul 02 06:20:49 blackbox kernel: [295890.975438] [<ffffffff88e37627>] x86_64_start_kernel+0xbd/0xc1
The next log entry occurs at 12:28, when I restarted the box.
Strangely though, there's entries in the system log between 6:20 and the restart. Specifically, I have a cron script that runs every hour on the NAS and makes a GET request to a webserver I run, on the public internet. Syslog was showing that my cron script was running every hour on the hour as it should.
I then logged into my web server and checked the logs for the webapp my NAS communicates with. The webserver was seeing the GET requests coming in from the NAS. It's definitely the NAS, it's the only device that would hit this particular URL on the server, and it also passes a unique token as a paramater, so it's definitely the NAS checking in.
If this happens again and the NAS becomes unreachable like this, I'll wait another hour and see if it is still making GET requests out to the webserver while otherwise unresponsive.
Wondering if 6.5.1 might have a fix for this, but I've read that people with Pro 6's are having fan issues with 6.5.1 so I deliberately didn't upgrade to that version.
