paulinde
May 11, 2019Aspirant
Amazon Drive not uploading file that grows over 1G
By accident I found that one of my files that had grown over 1G stopped uploading last month with no notification. Is there a new file size limit? Currently on 6.10.0
Marc_V
May 14, 2019NETGEAR Employee Retired
Hi paulinde
What type of file is that? and how it got that large? Usually files are not copied if they are in use at the time of backup. I don't think there's limit when it comes to upload or even download.
You can send me your NAS logs so we can check if available.
Regards
- paulindeMay 16, 2019Aspirant
Looking at log it seems to have happened after firmware update. File is an Outlook .pst
Would not let me attach log files here in forum.
- StephenBMay 16, 2019Guru - Experienced User
In general you shouldn't - there is some personal info in the log zip file.
You can attach screen shots, or save a portion of the lot as PDF. You can also cut/paste sections into a post (the "insert code" feature is a good way to do that).
- paulindeMay 18, 2019Aspirant
Attached file shows files and NAS log from time frame.
Attached Amazon Drive log file which shows a lot of errors, does not go back to time of firmware upgrade.
Attached file shows files and NAS log from time frame. File was not included for some reason.
