aroramoney
Oct 13, 2016Aspirant
Auto Back up with deletion
Hi, I want to schedule backup daily from a share in NAS to a Remote Drive using cifs option. i have done and it is working fine as one way backup except, Deletion from Destination Drive is NOT ...
aroramoney
Hi stephen,
thanks for reply , actaully total data size is around 3 tb , we cannot delete on daily basis .
is this possible without CIFS ? local NAS to REMOTE HDD one way back up with delete enabled during sync ?
Oct 13, 2016Guru - Experienced User
Yes, the option to delete files on the destination that are no longer on the source is available if you use rsync.
Note that leaving a comment in the exchange is not the same as voting for the idea.
- aroramoneyOct 13, 2016Aspirant
Hi stephen ,
- how to configure that , as i am not able to do so.
- is something to be enabled at client end.
- is there anydrawback of using rsync as compared to cifs.
- pl help with configuration document if any to configure rsync.
- pl see attachement / pic above
thnx,
- StephenBOct 13, 2016Guru - Experienced User
2) You need an rsync server installed on the destination share. What is the destination (a Windows PC??? Something else?)
3) Overall rsync throughput is slower than CIFS backup, but since it is incremental it generally works out faster in the end.
