chadwixk
Dec 20, 2019Aspirant
Bug - Quota Issues? Error: 1002030001
I am getting the Not Enough Free Space error (as referred to here), but do not have set quotas. The disk has 875GB free. The share properties shows the quota section blank. Is there a default or ...
chadwixk
Dec 23, 2019Aspirant
Thanks for pointing that settings section out, I never stumbled across it before.
Yes, the Quota checkbox is checked. Unfortunately, trying to uncheck and apply gives an error:
Model: ReadyNAS 102
Firmware: 6.10.2
Context: system_wnd_prop_volume
Error:
1014019994
Dec 23, 2019Guru - Experienced User
Can you download the log zip file?
