Fragglecasper
Nov 30, 2019Aspirant
cannot connect to readynas nvx RNDX4210
IN DIRE !! need of help, so my operating system which is windows 7 pro, was corrupted and acting up and was restarting and shutting down and was just causing me all troubles, so i decided to start fr...
Nov 30, 2019Guru - Experienced User
Fragglecasper wrote:
i have logged into ReadyCloud
Not an option. ReadyCloud only works with OS-6 NAS (which run 6.x firmware, not 4.2 firmware).
What happens when you enter \\192.168.1.16 into the file explorer address bar? Be care to use the correct slash - // will launch your browser, which isn't what we want.
Also, do you recall the admin password for your NAS? I am wondering, because you seem to be confused on screenshot 3. That normally gets you into the NAS web UI (called frontview), and you are supposed to enter admin as the username, and the NAS admin password when you see that pop-up.
Fragglecasper
also thank you for contacting me back so soon man, honestly
