sdis42
Aug 09, 2024Aspirant
Data recovery after RNDX4210 crashed
Hello everyone,
I had an electrical issue with a RNDX4210 a few days ago. Not just power unit get broke but the whole motherboard, since I manage to find a functional ATX power supply but unable to power on the godamn box...
Luckily I found the same model from a seller, hoping that it would go easily on recovery just by factory reseting the new one (with a new disk) and plug into it disks from the previous one, as described here (except I do it with both the same version) :
But it didn't really works... I plugged the 4 disks containing data but they failed SMART test except for one.
It seems that the electric indident may have damaged the disks.
So, at that point I'm stuck. I request some advices, in case you'll have ideas on that subject or experiment the same issue.
I really need those data, as you can guess...
Any help would be appreciated.
Thanks eveyone.
David / French IT tech
If the drives are that damaged, there is probably no recovery except very expensive recovery by a company that specializes in it. And they won't guarantee it'll even work.
If they are accessible at all, you could try cloning them to new drives, but that is a long shot (especially since you need at least two of the three to succeed.
This is just one of the reasons StephenB and I are always stressing the need for backup. Of course, in your case, another NAS or a USB drive connected as a backup may have also been damaged.
- SandsharkSensei
- sdis42Aspirant
Oh well, that's probably the only thing left to do. You're so right about backing up data...
Thanks a lot anyway
