KayZak
Nov 21, 2016Aspirant
Cannot Connect to ReadyNAS Replicate
I have 2 ReadyNASes that were previously connected to a ReadyNAS replicate account. I factory restored one of the ReadyNASes then took the other off the ReadyNAS replicate account because I was havin...
Jan 22, 2017Guru - Experienced User
OZ_DHB wrote:
Appreciate any thoughts on resolution please.
I don't really have any, but did want to suggest that if both ReadyNAS are on the main network that you should check out ReadyDR.
OZ_DHB
Jan 23, 2017Aspirant
Thanks StephenB, I'll give that a try.
May take until the weekend to have a go with it as the family are still verifying that all their files have made it across to the new disks and not until then will I blow away the old ones.
I'll revert to let you know what I find out and how it goes.
Thanks
- StephenBJan 23, 2017Guru - Experienced User
rsync of course is another option, and is the best choice if you want to simply copy the shares to the destination machine.
ReadyDR is similar to replicate in functionality.
