c13_reis
Feb 05, 2017Aspirant
Cannot turn on ReadyCLOUD RN104
Hi, I have a ReadyNAS 104 Firmware 6.6.1 ReadyNAS OS 6.6.1 I cannot turn ReadyCloud on. I slide the greyed Off swith across to On and then it turns Off after 4-5 seconds. Could you help me out. ...
- Feb 08, 2017
This is fixed. A configuration file was not updated properly and the old ReadyCLOUD account had not been linked to the SSO account. Also the services config needed updating to indicate that ReadyCLOUD was on.
mdgm-ntgr
Feb 06, 2017NETGEAR Employee Retired
Thanks for the logs. Looks like there is a configuration file that wasn't upgraded properly. I've sent you a PM.
mdgm-ntgr
Feb 08, 2017NETGEAR Employee Retired
- c13_reisFeb 08, 2017Aspirant
Awesome, thank you so much!!!
Chris
