icer91
Feb 09, 2017Aspirant
Cannot turn on ReadyCLOUD RN104
I have the same problem, where the ReadyCLOUD button switches back to 'off' everytime I click 'on'
Are there instructions on how to update the configuration file and the services config to make the needed changes?
Thanks!
icer91 your system was missing the serial number and MAC addresses for the ethernet ports. So I fixed that.
I also made sure you had the latest version of a config file.
- mdgm-ntgrNETGEAR Employee Retired
I've sent you a PM.
- icer91Aspirant
Thanks so much for your help! I'm not sure what you did, but it's working as it should now.
Thanks again!
