nass06
Feb 17, 2015Aspirant
Can't ping 1fichier.com
Hi, I'm on Readynas 102 firmware 6.2.2 and I can't ping this website 1fichier.com. I'm on ip static and my dns server is ok, I can ping this website from my pc without any problem. I added the ip ...
Feb 17, 2015Guru - Experienced User
Do you have ReadyCloud enabled on the NAS?
1fichier.com has a 5.x.x.x address. ReadyCloud hijacks that address range for its VPN, which is why you can't reach it.
If you disable ReadyCloud you probably will be able to ping it.
