gouzou
May 20, 2016Aspirant
can't see home folder in readycloud
Hi all, I have setup my ReadyNAS through the web portal; created a home folder and uploaded all my files. I have also installed the readycloud for windows in the same pc, logged in with my acco...
- Sep 09, 2016
Hello gouzou,
What's the model number of your NAS?
Have you tried accessing one of the shares that you can see via ReadyCloud app? This will open a Windows explorer and get you access the shares through SMB protocol, from there you should be able to click the Leafp2p IP of the NAS in the address bar that will take you to the current shares of the NAS which should include the home share of the account you are currently using.
gouzou
Aug 23, 2016Aspirant
Dear Brian,
Thank you very much for this.
Kind regards
Yannis
Kind regards
Yannis
BrianL2
Aug 23, 2016NETGEAR Employee Retired
Hi gouzou,
You're welcome. You can also raise this issue to our support team and they will forward your support ticket to Engineering.
Kind regards,
BrianL
NETGEAR Community Team
