aniraghome's avatar
Apr 28, 2018
ReadyCloud Folder Not Available
Ref: https://community.netgear.com/t5/ReadyCLOUD/Ready-Cloud-Folder-Not-Available/m-p/1553051#M10268
no luck with that for me i left and rejoined still keep getting the same error "network error" on my iphone readycould app
  • JohnCM_S's avatar
    JohnCM_S
    May 12, 2018
    Hi aniraghome,
    There is a new version of Readycloud app for iOS (2.0.2). You may try installing that and see if that will resolve the issue.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi aniraghome
    What FW is installed on your NAS? Have you tried installing v2.0.1?
    Please make sure that you are connected to the LAN or thru mobile data when trying to connect and also your NAS should have the Internet and Services check marks available.
    You can also check the Network settings of your NAS and Add DNS 8.8.8.8 and your Router address.
    Hope this helps!
    Regards
    • aniraghome's avatar
      aniraghome
      Tutor
      Yes i have installed 2.0.1 app on my iphone connected to LAN . Both internet and services are green checked always. Cloud does show my nas its just not connecting. It gives a message network error.
      • Marc_V's avatar
        Marc_V
        Can you provide us a Screenshot of the error? Can you login and access your NAS when using the portal?
ProSupport for Business
