aniraghome
Apr 28, 2018Tutor
ReadyCloud Folder Not Available
Ref: https://community.netgear.com/t5/ReadyCLOUD/Ready-Cloud-Folder-Not-Available/m-p/1553051#M10268
no luck with that for me i left and rejoined still keep getting the same error "network erro...
- May 12, 2018
Hi aniraghome,
There is a new version of Readycloud app for iOS (2.0.2). You may try installing that and see if that will resolve the issue.
aniraghome
May 02, 2018Tutor
Yes i have installed 2.0.1 app on my iphone connected to LAN . Both internet and services are green checked always. Cloud does show my nas its just not connecting. It gives a message network error.
Marc_V
May 02, 2018NETGEAR Employee Retired
Can you provide us a Screenshot of the error? Can you login and access your NAS when using the portal?
- aniraghomeMay 03, 2018TutorThe error message is a small pop up message “network error occurred “
Yes i can login to readynas cloud portal on computer it even discovers the nas.- Marc_VMay 07, 2018NETGEAR Employee Retired
Hi aniraghome
Can you try connecting to ReadyCloud App using mobile data instead of LAN? Have you tried using a different device when connecting?
Regards
- aniraghomeMay 07, 2018TutorHi Marc_V
Yes i am able to upload via cellular data i get the error with my home wifi.
I also tried with a different iphone and ipad same issue cellular data works wifi doesnt
