Andy-J
Oct 16, 2017Initiate
Continous backup stopped working
Hi, I've just updated my Readynas 212 firmware to latest version 6.8.1 and have now discovered the continuous backup setting no longer works. Before the update any files/folders created or modified ...
jozifa
Oct 16, 2017Aspirant
I have the same problem with my ReadyNas 312. New firmware on iphone version 2.0.0(2027) is not backing up, showing uploading, but not progress. ReadyNas firmware is updated as well.
- BingkeXOct 16, 2017NETGEAR Expert
Hi jozifa,
What is your iphone's ios version? Which network does you iphone use? Same LAN with your nas, different LAN, or 3G/4G?
Would you please try to disable and enable backup again?
Best Regards.
- jozifaNov 19, 2017Aspirant
Hi,
Sorry for late reply due to my email setting error. My iphone 5s version is ios 11.1.2. The media backing up is not uploading. It is on same LAN. The media backup on my other devices, ipads, iphoneSE seems working. I also have tried reset, en/disble it and even reinstall the Readycloud app.
- Marc_VNov 23, 2017NETGEAR Employee Retired
Hi jozifa
Do other devices where backup is working also run on iOS 11.2? Have you tried using Mobile connection? What is the Firmware version installed on your ReadyNAS?
Do media backups work before your update to iOS 11.2 or ReadyNAS 6.9.0? You may want to try 6.9.1 if you have not updated yet.
I would suggest contacting NETGEAR Support and log a case so experts can assist with troubleshooting and escalate the case to a higher tier if needed.
Hi Andy-J
Have you contacted ReadyNAS Vault support about this? If not I suggest contacting them. You may have to update to the latest version of the application for Vault.
Regards
- jozifaNov 28, 2017Aspirant
Hi BingkeX :
IOS 11.1.2, they are on same home network. cheers
