Andy-J
Oct 16, 2017Initiate
Continous backup stopped working
Hi, I've just updated my Readynas 212 firmware to latest version 6.8.1 and have now discovered the continuous backup setting no longer works. Before the update any files/folders created or modified ...
jozifa
Oct 16, 2017Aspirant
I have the same problem with my ReadyNas 312. New firmware on iphone version 2.0.0(2027) is not backing up, showing uploading, but not progress. ReadyNas firmware is updated as well.
BingkeX
Oct 16, 2017NETGEAR Expert
Hi jozifa,
What is your iphone's ios version? Which network does you iphone use? Same LAN with your nas, different LAN, or 3G/4G?
Would you please try to disable and enable backup again?
Best Regards.
