memox
Jan 21, 2022Follower
Currently impossible to download readycloud
http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe redirects to http://readycloud.netgear.com/client/en/welcome.html
- Jan 24, 2022
Please try again, it should work now. Thank you and sorry for the inconvenience.
YeZ
Jan 22, 2022NETGEAR Expert
As a workaround, you can go to http://support.netgear.com and enter the NAS model to search its support page, the product's support page has the ReadyCLOUD download links.
For example:
https://www.netgear.com/support/product/RN102.aspx#download
Jan 23, 2022Guru - Experienced User
For example:
No, that has the same redirect issue.
The problem is that neither https://readycloud.netgear.com/client/install/ReadyCloudSetup.exe nor https://readycloud.netgear.com/client/install/ReadyCLOUD.pkg work.
The support pages all use these URLs, so they all fail the same way.
