Syd_vld
Mar 29, 2018Aspirant
delete readycloud account
Hi. I need to delete the account xxx.xxxx@xxxxxxxxx.com and its data from the NETGEAR cloud sign-on system. I want to change an e-mail in my current acc - yyy@yyyy.yy to xxx.xxxx@xxxxxxxxx.com. And then I want to change the binding of my device (now yyy@yyyy.yy) and change the cloud user in the device.
- Syd_vldAspirant
you are so supporty
- Retired_Member
You can change email at https://readycloud.netgear.com,after changing your previous MyNETGEAR account will be removed from NETGEAR server.
- Syd_vldAspirant
Hi.
Sounds good but....
and processing processing processing processing processing processing processing processing......
and nothing happens
- Aug 04, 2022Retired_Member
- Dec 11, 2018Retired_Member
- Feb 17, 2021Retired_Member
- May 30, 2020Retired_Member
