Daf1
May 30, 2016Tutor
Different versions of ReadyCloud on ReadyNas 104 6.5.0
I have two ReadyNAS 104's
Both recently upgraded to 6.5.0
A while back I accidentally disabled ReadyCloud on the first and then added it again - then after that had to log in to admin Pages using "admin" account rather than main user account. It works anyway so am Ok with that.
Since upgrade to 6.5.0 - I need to use "admin" account on both.
Now, going onto "Cloud" tab of both - the ReadyCloud option seems to be significantly different on both. Settings button also gived different options.
Not a major issue as I don't use it much but thought I'd check why this is.
Older machine (ReadyCloud disabled + re-added):
Settings:
Newer box:
Settings:
Thoughts ?
Clear your web browser cache, close your web browser then reopen the web admin interface. The web admin UI should then display correctly for both systems.
- mdgm-ntgrNETGEAR Employee Retired
