Daf1's avatar
Daf1
Tutor
May 30, 2016
Different versions of ReadyCloud on ReadyNas 104 6.5.0
I have two ReadyNAS 104's
Both recently upgraded to 6.5.0
A while back I accidentally disabled ReadyCloud on the first and then added it again - then after that had to log in to admin Pages using "admin" account rather than main user account. It works anyway so am Ok with that.
Since upgrade to 6.5.0 - I need to use "admin" account on both.
Now, going onto "Cloud" tab of both - the ReadyCloud option seems to be significantly different on both. Settings button also gived different options.
Not a major issue as I don't use it much but thought I'd check why this is.
Older machine (ReadyCloud disabled + re-added):
Old - ReadyCLoud
Settings:
Old - settings
Newer box:
New - ReadyCloud
Settings:
Thoughts ?
  • Clear your web browser cache, close your web browser then reopen the web admin interface. The web admin UI should then display correctly for both systems.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    • Daf1's avatar
      Daf1
      Tutor
      That did the job - thanks
ProSupport for Business
