augur's avatar
augur
Apprentice
Sep 25, 2017
Disable ReadyCloud sync on mobile access
Hi.
I like to use the ReadyCLOUD client but like to disable folder sync if I am using WAN connection. Is that somehow possible?
Cheers,
Nils
  • BingkeX's avatar
    BingkeX
    NETGEAR Expert
    Hi augur,
    Which Readycloud client do you use? Windows/MAC client or IOS/Android readycloud app?
    For Windows/MAC client, there is no way to disable folder sync only with WAN connection. We have option to "pause sync" and "resume sync" for a sync job to disable folder sync regardless connection methods.
    For IOS/Android readycloud app, there is an option "Use Cellular Data" to disable media backup when connection is 3G/4G, but no option to disable media backup only with WAN connection.
    Hope this is helpful to you.
    Best Regards.
    • augur's avatar
      augur
      Apprentice
      Hi,
      using the newest windows client. Would be a nice feature because windows will detect mobile connections and can stop syncronization like in Outlook or OneDrive. Can I perhaps constrain syncrhnization in local connections in general? Actually the clients detects if the ReadyNAS is in the local network so the basic functions are available.
      Cheers,
      Nils
      • BingkeX's avatar
        BingkeX
        NETGEAR Expert
        Hi augur,
        PM have sent.
        Best Regards.
ProSupport for Business
