augur
Sep 25, 2017Apprentice
Disable ReadyCloud sync on mobile access
Hi. I like to use the ReadyCLOUD client but like to disable folder sync if I am using WAN connection. Is that somehow possible? Cheers, Nils
augur
Sep 26, 2017Apprentice
Hi,
using the newest windows client. Would be a nice feature because windows will detect mobile connections and can stop syncronization like in Outlook or OneDrive. Can I perhaps constrain syncrhnization in local connections in general? Actually the clients detects if the ReadyNAS is in the local network so the basic functions are available.
Cheers,
Nils
BingkeX
Sep 26, 2017NETGEAR Expert
Hi augur,
PM have sent.
Best Regards.
- augurOct 04, 2017Apprentice
Does anybody can post an idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage
I cannot post anything there because the labes/tags are ot known...
- StephenBOct 04, 2017Guru - Experienced User
Are you saying that it won't let you post an idea without a tag?
