augur
Sep 25, 2017Apprentice
Disable ReadyCloud sync on mobile access
Hi. I like to use the ReadyCLOUD client but like to disable folder sync if I am using WAN connection. Is that somehow possible? Cheers, Nils
BingkeX
Sep 26, 2017NETGEAR Expert
Hi augur,
PM have sent.
Best Regards.
augur
Oct 04, 2017Apprentice
Does anybody can post an idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage
I cannot post anything there because the labes/tags are ot known...
- StephenBOct 04, 2017Guru - Experienced User
Are you saying that it won't let you post an idea without a tag?
