augur
Sep 25, 2017Apprentice
Disable ReadyCloud sync on mobile access
Hi. I like to use the ReadyCLOUD client but like to disable folder sync if I am using WAN connection. Is that somehow possible? Cheers, Nils
augur
Oct 04, 2017Apprentice
Does anybody can post an idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage
I cannot post anything there because the labes/tags are ot known...
Oct 04, 2017Guru - Experienced User
Are you saying that it won't let you post an idea without a tag?
