dspj
Aug 04, 2015Aspirant
File copy froze Duo v1. Files and Admin now unreachable
A couple of days ago i was copying mp3's from my NAS. Copying suddenly froze and NAS dishe network. I eventually was able to reboot the Duo manually (soft rebooat; long-press-blinks-shut down) ...
- Aug 04, 2015
Do you have a backup? If not first confirm that you have a Duo v1 by using this guide:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Then your priority should be to try to backup the data. You can use Linux reader on a PC to read disk 1 from the duo v1. It won't work with disk 2 (usually) and this won't work with later 2 bay models.
http://www.diskinternals.com/linux-reader/What disks are in the nas?
What firmware is on the duo?
Did you have ssh enabled?
Alternatively you can start by testing the disks:
Power down the nas, remove each disk and test them with vendor tools on a PC, use the long or extended tests.
If the disks are ok, what you do after this depends on the backup situation, and whether you have ssh enabled.
vandermerwe
Aug 04, 2015Master
