dspj
Aug 04, 2015Aspirant
File copy froze Duo v1. Files and Admin now unreachable
A couple of days ago i was copying mp3's from my NAS. Copying suddenly froze and NAS dishe network. I eventually was able to reboot the Duo manually (soft rebooat; long-press-blinks-shut down) ...
- Aug 04, 2015
Do you have a backup? If not first confirm that you have a Duo v1 by using this guide:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Then your priority should be to try to backup the data. You can use Linux reader on a PC to read disk 1 from the duo v1. It won't work with disk 2 (usually) and this won't work with later 2 bay models.
http://www.diskinternals.com/linux-reader/What disks are in the nas?
What firmware is on the duo?
Did you have ssh enabled?
Alternatively you can start by testing the disks:
Power down the nas, remove each disk and test them with vendor tools on a PC, use the long or extended tests.
If the disks are ok, what you do after this depends on the backup situation, and whether you have ssh enabled.
dspj
It's definitely a v1. Bought long before 2011.
Most questions are hard to answer as i cannot check...but perhaps i Have a saved config file (if that's readable to anyone? Should I post file if I find it?)
FW-version is the next to last as i wasn't able to perform that update neither online nor with downloadfile. Can't remember the number...
Disks are two 1 tb I think and I don't believe ssh was switched on (that's for Remote management, right?)
Backup status is mixed. Personal photos I have copies, for music collection as well. Then some films, audiobooks and software copies I can mostly live without. But camcorder videos I only have on original tape, some were edited on the NAS.
So replacing these is weeks if not months of 9-5 work - and I doubt that I would manage to find everything.
(Feels almost time to look for a gun or a piece a piece rope now...)
Linux is not my turf.
vandermerwe
Aug 05, 2015Master
It is probably worth having a look at disk 1 with Linux reader. You do not need Linux skills to do this and it shouldn't adversely affect the chances of data recovery subsequently. Just make sure you remove disk 1 with the nas off, then replace it with the nas off when you are finished.
Otherwise follow mdgm's advice.
