Bertramrambert
Nov 12, 2017Aspirant
File Synch
Hi community, I am using a ReadyNAS Duo v2 togehter with Windows 10 Desktops and Laptops. The idea is that, in my home network only, some specified files will be synchronized automatically betwee...
Sandshark
Nov 12, 2017Sensei
The end of service for ReadyNAS Remote was announced as Sept 30. Not having an active system that runs it, I cannot verify it happened. But it certainly will soon if it has not already. I do not know of any suitable replacement that will run on your older NAS. But there are plenty of sync applications for Windows 10 that should work with the NAS as the target.
Bertramrambert
Nov 13, 2017Aspirant
Thanks! Ok, that sounds not god :(
Which synch applications for Windows 10 do you mean? Are they part of Windows 10 or are you talking about 3rd party applications? Do you have experience with some of them?
- SandsharkNov 13, 2017Sensei
3rd party applications. Since I put all of my important data directly on the NAS (which is backed up), I don't have a need for sync myself. But I have looked at SyncBack Free and FreeFileSync and both look like good options. I know somebody using FreeFileSinc to keep his DJ music synced to his backup drive, but it's a DAS, not a NAS..
