Bertramrambert
Nov 12, 2017Aspirant
File Synch
Hi community, I am using a ReadyNAS Duo v2 togehter with Windows 10 Desktops and Laptops. The idea is that, in my home network only, some specified files will be synchronized automatically betwee...
Bertramrambert
Nov 13, 2017Aspirant
Thanks! Ok, that sounds not god :(
Which synch applications for Windows 10 do you mean? Are they part of Windows 10 or are you talking about 3rd party applications? Do you have experience with some of them?
Sandshark
Nov 13, 2017Sensei
3rd party applications. Since I put all of my important data directly on the NAS (which is backed up), I don't have a need for sync myself. But I have looked at SyncBack Free and FreeFileSync and both look like good options. I know somebody using FreeFileSinc to keep his DJ music synced to his backup drive, but it's a DAS, not a NAS..
