dcheitel
Jan 16, 2025Aspirant
Firmware update Readynas 102
I am trying to update firmware on my readynas 102. I get the shown error when attempting the update using check for updates function. please advise if able. Thank you
Jan 17, 2025Guru - Experienced User
Are you getting the error when you check for the update?
If so, then manually download the update from https://kb.netgear.com/31116/ReadyNAS-OS-Version-6-5-2
Then extract the image from the zip file, and use the manual update function on system->settings to install it.
Or are you getting it when the system applies the update?
If this is the case, try rebooting the NAS, and then check the firmware version again.
- dcheitelJan 17, 2025Aspirant
actually getting errors both ways. when trying to do the file download and manual install it says unrecognized server error.
